Acer Nitro 5 AN517-51-56YW Touch Pad Replacement
  1. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
  4. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
    • Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
    • Lift the adhesive ribbon to be able to remove the touchpad.
    • Do not remove the ribbon completely, only the part that is on the touchpad.
  5. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the touchpad towards you from the bottom.
Giovanni Lopez
crwdns2935283:009/15/22crwdne2935283:0
88 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-1, Lane Fall 2022 crwdns2935289:0University of Memphis, Team 3-1, Lane Fall 2022crwdne2935289:0
UM-LANE-F22S3G1
crwdns2942667:0crwdne2942667:0 460
