This guide will teach you how to replace the track pad. You may have to perform this if your trackpad does not accurately read your input.
Turn the laptop over so its underside is up.
Use a Phillips #0 screwdriver to remove all 7 mm screws from the bottom cover.
Pop the cover off around the edges.
Remove the adhesive from the battery.
Use a Phillips #0 screwdriver to remove the two 5 mm screws.
Use a Phillips #0 screwdriver to remove the two 3 mm screws.
Pull the touchpad up and out of the computer.
