Make sure the device is off and unplugged from power.
Flip the device so the bottom is facing up.
Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
Lift the top left and right corners up and away from the device.
Remove the panel from the laptop.
Remove the single screw from the SSD using a Phillips #1 screwdriver.
Gently pull the drive to the left to remove it from the laptop.
