Acer Nitro 5 AN515-55-55M1 Fan Replacement
  1. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
  5. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the seven cables from the motherboard using an iFixit opening tool.
  6. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
  7. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
    • Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
    • Lift the taped wires off of the fans on the right and left sides.
  8. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the right side of the motherboard.
    • The cables may need some guidance to leave the management holes on the motherboard.
    • Continue to lift at an angle until there is a give.
    • Remove the motherboard and fans from the laptop.
  9. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the two fan connectors from each side of the motherboard using an opening tool.
  10. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Both fans are loose at this point and are only being held in by thermal tape.
    • Lift both fans up on each side and fold over the heat pipe.
  11. Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-55-55M1 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the fan away from the heat pipe on both sides of the motherboard.
    • The tape will separate off of the heat pipe.
Samuel Rouillard
crwdns2935283:003/30/21crwdne2935283:0
681 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-4, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S1G4
crwdns2942667:0crwdne2942667:0 1,895
