Acer Nitro 5 AN515-54-728C Battery Replacement
  1. Acer Nitro 5 AN515-54-728C Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Step 1: Removing Bottom Plate Locate and unscrew all screws attaching bottom of laptop. Slowly remove back plate from corners. There will be popping sounds from the plastic clips releasing. This is normal.
  2. Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Step 2: Disconnect Battery Locate the battery’s connection to the rest of the computer, at the top left of the battery. Use flat, plastic tool to help pry the plastic connection away.
  3. Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic tool to slide the battery connector out of its socket on motherboard.
  4. Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Step 4: Unscrew Battery Locate the two screws holding battery in place. Use screwdriver to remove the screws
  5. Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Step 5: Remove Battery Use flat plastic tool to pull clip at the bottom right of the battery back while carefully removing it.
  6. Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Step 6: Install new battery When placing new battery, make sure to line up the screw hole and the plastic cross with the two holes. Screw battery into the laptop case. Insert connection cable back into the computer.
  7. Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Nitro 5 AN515-54-728C Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Step 7: Replace bottom plate Apply pressure around the edges to ensure all attachment points meet. Screw bottom plate to the rest of the body
Jake Buchanan
crwdns2935283:011/29/23crwdne2935283:0
172 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 438
