Use this guide to replace the TouchPad in the Acer Nitro 5 Acer Nitro 5 AN515-53-55G9. This laptop has a track pad that can be replaced if damaged or broken.
Flip the laptop upside down so that the bottom is facing up.
Identify the RAM tray on the bottom of the laptop.
Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
Remove the RAM tray cover by prying up with a spudger.
Identify the Hard Drive tray to the left side of the laptop.
Remove screw with a #0 Philips screwdriver.
Lift up the Slot covering using a spunger.
Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
Remove the screws from the hard drive and remove it from the device.
Carefully remove the back shell from the device working your way around all the edges.
Removing the back shell of the computer and it will look like this.
The battery for the device is located at the bottom middle of the laptop at this orientation.
Locate the connector of the battery to the motherboard.
Using your fingers, slide out the connector.
Locate the Touchpad in the lower middle of the device.
Locate and remove the 4mm screws that hold the Touchpad in place.
Locate the Touchpad's connector.
Use a plastic spudger to pry up the small plastic clip on the connector port.
Gently pull the cable out of the port.
Lift up the Touchpad and remove it from the device.
And where can I find the track pad replacement? Thanks.
You can purchase replacement trackpads online, on eBay or Amazon or many other places by simply Google searching “Acer Nitro 5 Touchpad Part”
