Acer Nitro 5 AN515-53-52FA Battery Replacement
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery up and out of the laptop.
Alfredo Prieto
crwdns2935283:009/01/22crwdne2935283:0
926 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-3, Pee Fall 2022 crwdns2935289:0Gateway, Team 1-3, Pee Fall 2022crwdne2935289:0
GCC-PEE-F22S1G3
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - crwdns2934203:0crwdne2934203:0
Can I use a Jimmy instead of the opening picks?
I used a small standard screwdriver to "CAREFULL" separate the back plate. Suggest you have a can of air to clean the dust and crumbs off the motherboard
Christopher Suhre - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 86
crwdns2942667:0crwdne2942667:0 2,453
