Use this guide to replace the battery in the Acer Nitro 5 AN515-53-52FA laptop.
Before doing this guide please make sure there is no external power connected and that nothing is on. This 4-cell battery is the power supply, without it there would be no way to run the laptop. With this guide you will be able to replace the battery with a new one.
If your battery is dying at an alarming rate than normal, this is a great indication that you'll need to replace it. If there is any bulge on the battery, remove it immediately/safely and send it to a trusted disposable place.
Flip the laptop upside down so that the bottom is facing up.
Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
Use the opening pick to work your way around the edges to remove the bottom case carefully.
Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
Disconnect the battery's motherboard connector with your fingers.
Lift the battery up and out of the laptop.
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
When I was closing it up I just put it over the components and got the screws back in and it was working fine
Can I use a Jimmy instead of the opening picks?
If you're talking about the iFixIt Jimmy then I should say to be careful to not damage anything inside
I used a small standard screwdriver to "CAREFULL" separate the back plate. Suggest you have a can of air to clean the dust and crumbs off the motherboard
