This guide will walk you through the steps of replacing a malfunctioning or non-functional fan in an Acer Nitro 5 AN515-44-R70B. If your laptop is generating excessive heat or noise, especially during resource-intensive activities like gaming, it could be a sign of a fan-related issue.
Flip the laptop upside down so that the bottom is facing up.
Use the Phillips #0 screwdriver to remove the eleven M2.5x6.0 size screws holding the back cover in place.
Carefully remove the back shell from the device.
For extra caution slide out the battery cable from its connector using your fingers.
Using your fingers, slide out the two fan cables from their connectors.
Remove the gaffer tape next to the fan.
Use the Phillips #0 screwdriver to remove the four M2.5x6.0 size screws holding the fan assembly in place.
You can now remove the old fans and replace them with new ones.
Im having trouble taking off the back shell, since the tolerances are too low to get anything in there besides the back with the charger port, in which case the part covering the hinge just pops off, instead of the back cover, is there anything I can do in this situation or do I just need something thinner to pry it off? I've been using an old credit card btw.
