Acer Iconia W510 Vibration Motor Replacement
  1. Acer Iconia W510 Vibration Motor Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
    • Give the tool a twist to the left to start separating the clips.
    • Work your way to the corner, prying and twisting to pop the clips as you go.
  2. Acer Iconia W510 Vibration Motor Replacement, Right Side: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Right Side: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Right Side: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
    • Continue as before, prying and twisting to release the catches.
  3. Acer Iconia W510 Vibration Motor Replacement, Top Edge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Top Edge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue along the top edge as before
    • When you get to the corner, be careful not to insert the tool in the space below the power on symbol. There is a delicate clip there that is easy to break if you're prying with the tool. (Yes, I'm speaking from experience. Don't be me.)
  4. Acer Iconia W510 Vibration Motor Replacement, Left Side: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Left Side: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the left side of the tablet.
  5. Acer Iconia W510 Vibration Motor Replacement, Bottom Edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Bottom Edge: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
    • And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
  6. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear cover is removed.
  7. Acer Iconia W510 Vibration Motor Replacement, Unplug the Tablet Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Unplug the Tablet Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the tape securing the battery connector.
  8. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the plug by the tabs on either side and pull it straight out from the connector.
  9. Acer Iconia W510 Vibration Motor Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unstick the grounding tape from the charging connector.
  10. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, flip up the latch securing the charge port flex cable.
  11. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the pull tab on the flex cable and use it to pull the cable out of the connector.
  12. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The flex cable is lightly adhered to the display frame, so use a spudger to separate it.
  13. Acer Iconia W510 Vibration Motor Replacement, Vibrator Motor Disconnection: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Vibrator Motor Disconnection: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Vibrator Motor Disconnection: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.1mm Phillips screws.
  14. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the cable assembly over carefully, as it is still adhered to the frame by a thin strip of flex cable. Be careful not to break that strip.
  15. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the vibration motor from the charging port circuit board.
  16. Acer Iconia W510 Vibration Motor Replacement, Vibration Motor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Vibration Motor Replacement, Vibration Motor: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a pair of tweezers, lift the vibration motor out of its mounting bracket.
  17. Acer Iconia W510 Vibration Motor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The vibration motor is now free.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
75.717 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Oregonians crwdns2935289:0Oregonianscrwdne2935289:0
Community
crwdns2931471:08crwdne2931471:0
crwdns2935297:0193crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 48
