Acer Iconia W510 Speaker Replacement
  1. Acer Iconia W510 Speaker Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
    • Give the tool a twist to the left to start separating the clips.
    • Work your way to the corner, prying and twisting to pop the clips as you go.
  2. Acer Iconia W510 Speaker Replacement, Right Side: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Right Side: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Right Side: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
    • Continue as before, prying and twisting to release the catches.
  3. Acer Iconia W510 Speaker Replacement, Top Edge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Top Edge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue along the top edge as before
    • When you get to the corner, be careful not to insert the tool in the space below the power on symbol. There is a delicate clip there that is easy to break if you're prying with the tool. (Yes, I'm speaking from experience. Don't be me.)
  4. Acer Iconia W510 Speaker Replacement, Left Side: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Left Side: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the left side of the tablet.
  5. Acer Iconia W510 Speaker Replacement, Bottom Edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Bottom Edge: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
    • And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
  6. Acer Iconia W510 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear cover is removed.
  7. Acer Iconia W510 Speaker Replacement, Unplug the Tablet Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Unplug the Tablet Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the tape securing the battery connector.
  8. Acer Iconia W510 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the plug by the tabs on either side and pull it straight out from the connector.
  9. Acer Iconia W510 Speaker Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unstick the grounding tape from the charging connector.
  10. Acer Iconia W510 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, flip up the latch securing the charge port flex cable.
  11. Acer Iconia W510 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the pull tab on the flex cable and use it to pull the cable out of the connector.
  12. Acer Iconia W510 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia W510 Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The flex cable is lightly adhered to the display frame, so use a spudger to separate it.
  13. Acer Iconia W510 Speaker Replacement, Speakers: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Speakers: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Speakers: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the speakers.
    • Grasp the connector itself; do not pull on the wires to unplug the speakers.
  14. Acer Iconia W510 Speaker Replacement, Remove the Right Speaker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Remove the Right Speaker: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Remove the Right Speaker: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The speaker is lightly adhered to the case with double sided tape. Use a spudger to pry the speaker up to remove it.
  15. Acer Iconia W510 Speaker Replacement, Remove the Left Speaker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Remove the Left Speaker: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia W510 Speaker Replacement, Remove the Left Speaker: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat for the left speaker.
  16. Acer Iconia W510 Speaker Replacement, Deroute the Speaker Wires: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting at the left speaker, lift the wire out of the channel it sits in.
  17. Acer Iconia W510 Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the charging port flex cable back to clear the speaker cable channel.
  18. Acer Iconia W510 Speaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • One last tab to clear.
  19. Acer Iconia W510 Speaker Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And the speakers are free.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
75,729 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Oregonians crwdns2935289:0Oregonianscrwdne2935289:0
Community
crwdns2931471:08crwdne2931471:0
crwdns2935297:0193crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 60
