The Acer Iconia Tab A200 has a 10.1" Touchscreen display.
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
Using the plastic opening tool gently lift up the charging component out of its slot in the case.
Continue to lift up the cord until it is free from the case and only attached to the motherboard.
Disconnect the power component from the motherboard by pulling it out horizontally. Do not pull up on the cord only pull out
Lift up on the microphone cable to lift the microphone component away from the case.
Once the microphone has been lifted away from the case, disconnect the microphone cable from the motherboard by pulling the cable out horizontally. Do not lift up to remove.
After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
Once the screws are removed, lift up on the speakers to remove them from the case.
Once you have removed the speakers from the case, disconnect the speakers from the motherboard by pulling the cable out horizontally. Do not pull up on the cable.
Using the plastic opening tool unplug the green cable by placing the tool under where the cable meets the plug and lifting up.
After unplugging the green cable remove the black tape that secures the green cable to motherboard.
Using the plastic opening tool unplug the black cable by placing the tool under where the cable meets the plug and lift up.
Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00.
After the screws have been removed lift up on the motherboard to remove it from the case.
Using the pointed tip of the nylon spudger, pry the unit board off the case
Flip the device over, so that the screen is face up.
Using the metal spudgers pry apart and separate the screen from the device.
Looking forward to fixing this tablet a friend had given up on then gave to me. So funny how easily ppl give up!Thank you for this spectacular set of directions. Looks like it will be the one that works for the tablet I have.
MichelleE1 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how can i tell if there is any water damage?
Samuel Gentry - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
