Acer Iconia Tab 8 A1-860 Motherboard Replacement
  1. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, remove the two tabs shown by placing the spudger under the gray part of the connectors and pulling on the tabs.
  6. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws.
  7. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, push the tab where this belt connects to the motherboard to free it.
    • Use tweezers in order to pull the belt from its slot in the motherboard.
  8. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, push the tab connecting this belt to the motherboard.
    • Once the tab is pushed and the belt is free to move, use tweezers to pull it from the slot.
  9. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, pull upward on the end of this belt where it plugs into the motherboard.
  10. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the tweezers, grab the gray wire and move it from underneath the plastic piece shown in red.
    • Then place the tweezers on the end of the wire circled, and pull the piece from the motherboard.
  11. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers in order to lift a corner of this copper foil.
    • Then use a spudger to pull the copper foil from the motherboard.
    • If the copper foil does not remove easily, use an iOpener heating pad to release the adhesive.
  12. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the "void" sticker to reveal a 3 mm screw.
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  13. Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia Tab 8 A1-860 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the motherboard out of its slot in the rear case.
Michael Buchanan
crwdns2935283:004/01/19crwdne2935283:0
361 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G3, Harley Spring 2019 crwdns2935289:0IUPUI, Team S2-G3, Harley Spring 2019crwdne2935289:0
IUPUI-HARLEY-S19S2G3
crwdns2942667:0crwdne2942667:0 532
