Acer Iconia Tab 8 A1-840 Speaker Replacement
  1. Acer Iconia Tab 8 A1-840 Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Speaker Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
  5. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of the spudger to pry up and remove the battery cable.
  6. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Heavy-Duty Spudger
  7. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use fingers to pull the Zero Insertion Force (ZIF) cable from the motherboard.
  8. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use fingers to remove the smaller adjacent ZIF cable from the motherboard.
  9. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of the spudger to pry the battery up from all edges, and remove it from the back panel.
    • There is adhesive behind the battery that holds it in place. Be sure to pry slowly and carefully when removing the battery.
  10. Acer Iconia Tab 8 A1-840 Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers or the flat end of the spudger to carefully pull the connection loose.
  11. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pointy end of the spudger to remove the black tape holding the wires in place and completely free the wires.
  12. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5mm nut driver and Philips#000 bit to remove the four 1.5mm screws.
  13. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speakers after unscrewing the screws.
  14. Acer Iconia Tab 8 A1-840 Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spudger to loosen the wire and free the speaker.
Claire Posadas
crwdns2935283:010/18/16crwdne2935283:0
396 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 1-1, Rose Fall 2016 crwdns2935289:0UW Tacoma, Team 1-1, Rose Fall 2016crwdne2935289:0
UWT-ROSE-F16S1G1
crwdns2942667:0crwdne2942667:0 844
