This repair guide will show you how to replace the battery in your Acer Iconia One 8 B1-850.
To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
Remove the black piece of tape that is holding the red, yellow, and white wires in place.
Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
Carefully work a plastic spudger underneath the battery and pry it free.
