After the motherboard has been removed, you now have access to the power switch. You will need to use a plastic opening tool to pop the switch out.
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
Using the metal spudger, carefully pry open the back cover.
Unplug the connection cord from the motherboard.
Try to remove the battery by pulling on the blue tabs.
If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
Remove all of the tape surrounding the motherboard.
Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
Now, disconnect the two smaller black and red cords from the motherboard.
Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
Using the same screwdriver remove the other three screws on the motherboard.
Using the small plastic tool, carefully pry the motherboard out of the device.
Depress power switch using finger, and simultaneously pry in same direction with a plastic opening tool.
