Acer Iconia A1-810 Motherboard Replacement
  1. Acer Iconia A1-810 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
    I found my thumbnail worked better, and starting near one of the corners. The picture shows the tool inserted where it could easily damage the SD card mechanism.
    James Dellar - crwdns2934203:0crwdne2934203:0
  2. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
    This is a white connector, and it is easy to get fingernails to both ends to pull it out of the metal socket.
  4. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove battery from adhesive.
    There is a clear plastic tab to pull (being used in the photo), which lifts the battery in one, and unsticks it from the 2 or 3 sticky pads.
  5. Acer Iconia A1-810 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
    A No 0 cross point screwdriver worked perfectly well for these. There was a small black Acer sticker covering the one at the top right. All circled screws are the same length. In my case there was a small retaining plate between the two screws either side of the HDMI port (top left). The two screws in the rectangle at the left were significantly longer.
  6. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
    Disconnecting this was fiddly. It was even more fiddly to replace. The dark grey part of the connector on the board stays in place, and you need to slide the tail inside it. The orange tab was taped down at one edge.
  7. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift motherboard out.
    • The edges may be sharp.
John
crwdns2935283:001/29/15crwdne2935283:0
635 crwdns2915208:0crwdne2915208:0
UWT Liner: Group 3 crwdns2935289:0UWT Liner: Group 3crwdne2935289:0
Community
crwdns2947412:08crwdne2947412:0
I need main ic part num A1-810 iconia I need main ic
mehwish - crwdns2934203:0crwdne2934203:0
It was damage because high voltage
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
theblackfox2 - crwdns2934203:0crwdne2934203:0
Hi there i need acer lconia A3 main bord how much it will cost me ?
Muhammad - crwdns2934203:0crwdne2934203:0
own Acer tablet A1-811 that if i switch on it wouldnwouldn't come up and it will just be making noise.. Please what will probably be the problem
ebirraoyiza - crwdns2934203:0crwdne2934203:0
Please what is the way forward
crwdns2942667:0crwdne2942667:0 5,572
