Acer Icona W510 Charging Port Replacement
  1. Acer Icona W510 Charging Port Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
    • Give the tool a twist to the left to start separating the clips.
    • Work your way to the corner, prying and twisting to pop the clips as you go.
  2. Acer Icona W510 Charging Port Replacement, Right Side: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Right Side: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Right Side: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
    • Continue as before, prying and twisting to release the catches.
  3. Acer Icona W510 Charging Port Replacement, Top Edge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Top Edge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue along the top edge as before
    • When you get to the corner, be careful not to insert the tool in the space below the power on symbol. There is a delicate clip there that is easy to break if you're prying with the tool. (Yes, I'm speaking from experience. Don't be me.)
  4. Acer Icona W510 Charging Port Replacement, Left Side: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Left Side: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the left side of the tablet.
  5. Acer Icona W510 Charging Port Replacement, Bottom Edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Bottom Edge: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
    • And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
  6. Acer Icona W510 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear cover is removed.
  7. Acer Icona W510 Charging Port Replacement, Unplug the Tablet Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Unplug the Tablet Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the tape securing the battery connector.
  8. Acer Icona W510 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the plug by the tabs on either side and pull it straight out from the connector.
  9. Acer Icona W510 Charging Port Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Charging Port Disconnection: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unstick the grounding tape from the charging connector.
  10. Acer Icona W510 Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, flip up the latch securing the charge port flex cable.
  11. Acer Icona W510 Charging Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the pull tab on the flex cable and use it to pull the cable out of the connector.
  12. Acer Icona W510 Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The flex cable is lightly adhered to the display frame, so use a spudger to separate it.
  13. Acer Icona W510 Charging Port Replacement, Vibrator Motor Disconnection: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Vibrator Motor Disconnection: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Vibrator Motor Disconnection: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.1mm Phillips screws.
  14. Acer Icona W510 Charging Port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the cable assembly over carefully, as it is still adhered to the frame by a thin strip of flex cable. Be careful not to break that strip.
  15. Acer Icona W510 Charging Port Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the vibration motor from the charging port circuit board.
  16. Acer Icona W510 Charging Port Replacement, Charging Port: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Icona W510 Charging Port Replacement, Charging Port: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The flex cable is tightly secured to the frame and requires care to remove. Use a spudger and work slowly and methodically to separate it from the case.
  17. Acer Icona W510 Charging Port Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The flex cable is now free of the tablet.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
75,717 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Oregonians crwdns2935289:0Oregonianscrwdne2935289:0
Community
crwdns2931471:08crwdne2931471:0
crwdns2935297:0193crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 215
