Acer Ferrari 4005WLMi Disassembly
  1. Acer Ferrari 4005WLMi Disassembly, Remove battery and optical drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latches, then slide the battery back to remove it.
    • Release the latch and slide the optical drive out.
  2. Acer Ferrari 4005WLMi Disassembly, Remove memory, hard drive, and network adapter covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Each door is held in by two captive Philips screws.
  3. Acer Ferrari 4005WLMi Disassembly, Remove RAM and wireless module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Ferrari 4005WLMi Disassembly, Remove RAM and wireless module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Each stick is held in by two metal clips. You may want to use a small screwdriver or a plastic spudger to release them since they're hard to reach with your finger.
    • Carefully disconnect the two antenna cables by pulling up on them with a pair of tweezers.
    • The wireless module is held in the same way as the RAM, with two clips and no screws.
  4. Acer Ferrari 4005WLMi Disassembly, Remove the hard drive cage: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two M2.5 x 3 screws holding the drive cage in, then pull the plastic tab to the left to unplug the drive. Lift it out.
    • If you intend to replace the drive, remove the four M3 x 4 screws.
  5. Acer Ferrari 4005WLMi Disassembly, Remove bottom case screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 18 M2.5 x 7 screws.
    • Remove this screw.
  6. Acer Ferrari 4005WLMi Disassembly, Remove rear bottom case screws and hinge covers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Ferrari 4005WLMi Disassembly, Remove rear bottom case screws and hinge covers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 M2.5 x 3 screws holding the bottom case to the chassis.
    • Remove the two M2.5 x 3 screws (one per side) holding the hinge covers to the hinges. Without the screws, the covers should fall off or be easily pulled upwards.
    • Don't worry about the standoffs for the DVI port yet - we'll get to those later.
  7. Acer Ferrari 4005WLMi Disassembly, Remove keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Ferrari 4005WLMi Disassembly, Remove keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Ferrari 4005WLMi Disassembly, Remove keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in the two latches at the back of the keyboard, then lift the keyboard from the back and gently pull it towards the screen.
    • Be careful when removing the keyboard! The ribbon cable leading to the motherboard is quite short. Nothing in this step should require much force.
    • Release the retaining clip by gently pushing the two tabs away from the connector, then pull the cable out.
    • Those two latches are actually separate parts from the top cover. Isn't that cool?! Kudos to Acer for thoughtfulness and serviceability - designing those into the laptop cost them time and money when they could have just molded damage-prone tabs into the top cover.
  8. Acer Ferrari 4005WLMi Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five M2.5 x 7 screws.
    • Remove the two M2 x 4 screws. I recommend marking the screw holes with a Sharpie so you don't forget where they go, since they're different from the other five.
    • Unplug these three connectors. The ribbon cable at the bottom has no latches. Just pull it out gently.
    • Note the thermal pad on the touchpad bracket. The original ones on mine were pink, not gray; I've already replaced them in this machine.
    • Lift the top cover from the front and pull it towards you. Be gentle; this will take some fiddling, but it should come out without much force. (Picture TBA)
  9. Acer Ferrari 4005WLMi Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the speaker cables and the modem cable.
    • Disconnect this ribbon cable. I would recommend unplugging it at both ends and removing it entirely.
    • The other end of the modem cable shouldn't be loose on this side of the motherboard. There's a cutout that it feeds through, since the modem is on the other side. I forgot to reconnect it the last time I had this machine apart.
  10. Acer Ferrari 4005WLMi Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws marked by arrows on the motherboard's silkscreen. Lift the motherboard out of the bottom case. Some wiggling around may be required if it catches on any plastic parts.
  11. Acer Ferrari 4005WLMi Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Ferrari 4005WLMi Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws holding the modem in, then remove the modem by lifting it upwards.
    • Reassembly note: to reinstall the modem, line up the screw holes and press down. You should feel it pop into place.
  12. Acer Ferrari 4005WLMi Disassembly, Remove heatsink and fan assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan connector.
To reassemble the 4005WLMi, follow these instructions in reverse order, as well as the reassembly notes along the way.
Henry Jeynes
crwdns2935283:008/06/20crwdne2935283:0
471 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 751
