Acer E5-571-54FL Wi-Fi Card Replacement
  1. Acer E5-571-54FL Wi-Fi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Wi-Fi Card Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the Wi-Fi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
    • Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
    • Carefully lift the white and black coaxial cables up and forward to disconnect the them from the Wi-Fi card.
  15. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 3 mm screw from the upper left corner of the Wi-Fi card.
    • The edge of WiFi card will lift up as the screw is removed.
  16. Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL Wi-Fi Card Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the upper left corner of the Wi-Fi card with your fingers.
    • Gently pull the Wi-Fi card away from the socket.
Aaron Weissman
crwdns2935283:010/23/17crwdne2935283:0
1 043 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G8, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G8
crwdns2942667:0crwdne2942667:0 467
