Acer E5-571-54FL CPU Replacement
  1. Acer E5-571-54FL CPU Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer E5-571-54FL CPU Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer E5-571-54FL CPU Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery towards you to remove it from the laptop.
  4. Acer E5-571-54FL CPU Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer E5-571-54FL CPU Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer E5-571-54FL CPU Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer E5-571-54FL CPU Replacement, Cooling Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement, Cooling Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement, Cooling Fan: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the CPU cooling fan in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
  8. Acer E5-571-54FL CPU Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the tips of the ESD safe pointed tweezers between the plug and the socket of the fan connection.
    • Gently push the tweezers to the left to disconnect the fan plug.
    • Move the fan connector and its wires to free them from the motherboard and the Wi-Fi card.
  9. Acer E5-571-54FL CPU Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the curved end of the fan by about 30 degrees.
    • Use your hand to lift the fan up and to the right until it is clear of the case.
    • If you feel resistance, check if the fan connector and wires are stuck under the motherboard or under the Wi-Fi card. If the connector or wires are stuck, gently free them.
  10. Acer E5-571-54FL CPU Replacement, Wi-Fi Card: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement, Wi-Fi Card: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the Wi-Fi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
    • Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
    • Carefully lift the white and black coaxial cables up and forward to disconnect the them from the Wi-Fi card.
  11. Acer E5-571-54FL CPU Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 3 mm screw from the upper left corner of the Wi-Fi card.
    • The edge of WiFi card will lift up as the screw is removed.
  12. Acer E5-571-54FL CPU Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the upper left corner of the Wi-Fi card with your fingers.
    • Gently pull the Wi-Fi card away from the socket.
  13. Acer E5-571-54FL CPU Replacement, Hard Drive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement, Hard Drive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the hard drive and its carriage at the lower right corner of the laptop.
    • Release the USB port ribbon cable by using the plastic opening tool to carefully lift up the black locking tab of the ZIF connector.
    • Move the USB port ribbon cable to the side.
  14. Acer E5-571-54FL CPU Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws securing the hard drive carriage in place.
  15. Acer E5-571-54FL CPU Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the right side of the laptop in place with your right hand.
    • Put the fingers of your left hand along the top edge of the hard drive carriage.
    • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
    • This procedure may require more force then other procedures.
  16. Acer E5-571-54FL CPU Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the hard drive carriage on the edge closest to your body to remove it.
    • If doing the motherboard replacement guide, skip the next step.
  17. Acer E5-571-54FL CPU Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
    • Using a Phillips #0 screwdriver, remove the 3 mm screw to release the side of the hard drive from the carriage.
    • Repeat the previous bullet to remove the second 3 mm Phillips #0 screw.
  18. Acer E5-571-54FL CPU Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws.
  19. Acer E5-571-54FL CPU Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the tips of the ESD safe pointed tweezers between the plug and the socket of the speaker connection.
    • Gently push left to disconnect the speaker plug.
  20. Acer E5-571-54FL CPU Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your fingernails on each side of the screen connection plug. Gently push away from your body to disconnect the plug.
  21. Acer E5-571-54FL CPU Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift up on the right edge of the motherboard near the hard drive connector.
    • With minimal force, pull the motherboard to the right freeing the ports on the left from the case.
    • Put down the right side and allow the motherboard to rest in the case.
    • There is still one connection to be removed which lies underneath the motherboard.
    • Lift the left side of the motherboard up and turn it over so the ports are now facing right.
  22. Acer E5-571-54FL CPU Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the edge of the motherboard closest to your body with your non-dominant hand.
    • Grip the power connection wires with your dominant hand and gently pull away from your body to disconnect.
  23. Acer E5-571-54FL CPU Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the case.
  24. Acer E5-571-54FL CPU Replacement, CPU: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the laptop.
    • Flip the laptop upside down. Rotate the laptop so the battery faces you.
  25. Acer E5-571-54FL CPU Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery lock to the left using the spudger until you hear the battery release.
  26. Acer E5-571-54FL CPU Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert wisdom here.
  27. Acer E5-571-54FL CPU Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the outer 6 mm screws located on both the top and the bottom sides of the fan.
    • Detach the power cable by pulling it out.
    • Remove the cooling fan.
  28. Acer E5-571-54FL CPU Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 4 mm Phillips head screws that connect the hard drive to the motherboard.
    • Carefully detach the ZIF ribbon.
    • Remove the hard drive.
  29. Acer E5-571-54FL CPU Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any remaining screws holding down the motherboard.
    • Remove the motherboard.
  30. Acer E5-571-54FL CPU Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer E5-571-54FL CPU Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the Wi-Fi card by gently unplugging both wires connected to it.
Jennifer Hancock
crwdns2935283:009/19/19crwdne2935283:0
325 crwdns2915208:0crwdne2915208:0
University of North Alabama, Team S1-G2, Winner Fall 2019 crwdns2935289:0University of North Alabama, Team S1-G2, Winner Fall 2019crwdne2935289:0
UNA-WINNER-F19S1G2
... But this doesn't tell you how to replace the CPU!!
Robin Cowley - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 890
