Acer Chromebook cb3-532-c47c Display Hinge Replacement
  1. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Hinge Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the battery cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Unplug the WiFi Antenna Connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Unplug the WiFi Antenna Connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Deroute the Black WiFi Wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Deroute the Black WiFi Wire: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Deroute the White WiFi Wire: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Deroute the White WiFi Wire: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Disconnect the Display Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Disconnect the Display Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Disconnect the Display Cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove Right Hinge Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Hinge Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove Left Hinge Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Hinge Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  12. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the display assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the display assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the display assembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
  13. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the Front Bezel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the Front Bezel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the Front Bezel: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the display so the hinges are facing you, then pry off the bezel on the front of the screen using an opening pick or plastic opening tool.
  14. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the Left Hinge: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws securing the left hinge to the case; one at the top and three at the bottom.
    • Take out the left hinge.
  15. Acer Chromebook cb3-532-c47c Display Hinge Replacement, Remove the Right Hinge: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws securing the right hinge to the case; one at the top and three at the bottom.
    • Take out the right hinge.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
75.517 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 324
