Acer Chromebook cb3-532-c47c Display Assembly Replacement
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
74,767 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 389
