Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement
  1. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop to show the bottom side.
    • Remove the nine 6.5 mm screws using a JIS #1 screwdriver.
  2. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to separate the outer casing and panel; gently work the tool around the entire outer edge
    • The easiest place to start is at one of the hinges. The corners can be somewhat difficult.
    • Be gentle. The internal clips can snap.
  3. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the tape covering the wires.
  4. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery from its studs, and place it closer to you.
    • The battery is not clamped or screwed onto the frame. Once you disconnect the battery, you are able to safely remove it by picking it up.
    • Unplug the rainbow wires connecting the battery to the motherboard.
    • Be sure to only grab the white portion of the plug, do not overstretch the rainbow wires.
    • Remove the battery from the laptop.
  5. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4.6 mm screws holding the left-side screen bracket to the internal components using a JIS #1 screwdriver.
  6. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the bracket away from its original location.
  7. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clear tape securing the smaller wire.
    • Flip the small black clip securing the larger wire.
    • The wire below loosely sits inside the plug. It is fine if it comes out on its own after the clip is opened.
  8. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the smaller wire.
    • Lift the larger wire, if it is still in place.
  9. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4.6 mm screws holding the right-side screen bracket to the internal components using a JIS #1 screwdriver.
    • Disconnect the ribbon cable from the motherboard.
    • There is only one wire on the right side. It's similar to the larger wire on the previous side, but slightly wider.
  10. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the panel you've been working on.
    • Lift from the front edge of the panel, so that it and the screen form a 90 degree angle.
    • Pull the electrical panel straight back, away from the hinges/brackets. It shouldn't require any force.
  11. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement, Hinges: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement, Hinges: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the screen from the top casing using an opening tool.
  12. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Untuck the wires next to hinges.
    • Lift the corner of the screen respective to the first hinge. Maneuver the wire around the edge of the screen on the other side of the hinge. Gently press the wire down onto your work surface.
  13. Acer Chromebook Spin 714 CP714-2W-56B2 Hinges Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the screen from the hinge casing.
Ariana Lafitte
crwdns2935283:002/19/25crwdne2935283:0
469 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 7-2, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 7-2, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S7G2
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 62
