Use this guide to replace the battery in an Acer Chromebook Spin 714 (CP714-2W-56B2). You may need to replace your battery if you experience any of the following issues: significantly reduced battery life, frequent shutdowns despite a high battery charge percentage, the battery not charging properly, or the laptop refusing to turn on.
Flip the laptop to show the bottom side.
Remove the nine 6.5 mm screws using a JIS #1 screwdriver.
Use a plastic opening tool to separate the outer casing and panel; gently work the tool around the entire outer edge
Peel off the tape covering the wires.
Lift the battery from its studs, and place it closer to you.
Unplug the rainbow wires connecting the battery to the motherboard.
Remove the battery from the laptop.
