If your Acer Chromebook Spin 511 (C741L) N20Q8 is not turning on or losing its charge rapidly, the battery may be faulty and need a replacement.
By replacing the Chromebook's battery, it will be able to stay powered on for longer. It will no longer need to be charged as often.
Power down the device before performing the steps in the guide.
Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
Gently remove the electrical tape from the battery.
Detach the colored wires from the wire connector on the motherboard.
Remove the battery from the laptop.
