Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement
  1. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate screen casing using a nylon spudger and a metal spudger.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the tape back.
    • Lift the red bar laying across the connection with the spudger.
    • Pull the connection out.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two cords shown by gently pulling them apart near their connection point.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the connection by gently pulling on it.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unravel the cord from around the screen and lift up on the screen to remove.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, Display Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove all twelve 6 mm screws in the bottom panel of the Chromebook.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to pry open the Chromebook casing starting from the corners.
  8. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 6 mm hinge screws on the right side of the Chromebook.
  9. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the end of LCD cable that is connected to the motherboard. Lift the connector's ZIF tab and gently pull the ribbon cable free.
    • Disconnect the other end of the LCD cord from the left side of the motherboard.
  10. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD cable has been disconnected and can be removed by guiding it out of the hooks that keeps it in placed.
Bailey Johnson
crwdns2935283:003/21/22crwdne2935283:0
718 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 2-3, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 2-3, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S2G3
crwdns2942667:0crwdne2942667:0 711
