Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement
  1. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out by pulling upward.
  6. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the retaining flaps of the two ZIF connectors into the upright position using the flat end of the spudger.
    • Unplug the tabs from the connectors by gently pulling them out with the tweezers.
  7. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide back both sides of the locking mechanism of the touchpad using the narrow end of the spudger.
    • Unplug the trackpad wire by gently pulling it out of the connector with the tweezers.
  8. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the audio connector from the motherboard with the tweezers.
    • Be sure to pull the plug by holding it at the base, not yanking on the wires, as this could damage the device.
  9. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the speakers off of the device by hand.
    • They are held on only by a mild adhesive and should come off easily.
Harrison DeWitt
crwdns2935283:004/26/17crwdne2935283:0
Cal Poly, Team S23-G2, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S23-G2, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S23G2
Hi, do you know how to replace the microphone on this chromebook?
Álvaro Guzmán Parrochia - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 728
