Acer Chromebook R11 C738T-C44Z Speakers Replacement
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook R11 C738T-C44Z Speakers Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the speakers up and remove the cable from the system.
Connie Hernandez
crwdns2935283:009/01/21crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-4, Saknee Fall 2021 crwdns2935289:0Gateway, Team 1-4, Saknee Fall 2021crwdne2935289:0
GCC-SAKNEE-F21S1G4
crwdns2942667:0crwdne2942667:0 198
