This guide will show you how to remove the Acer Chromebook CP5-471-C0EX fan for replacement or repair. The fan and cooling system is an integral part of the computer. A poorly functioning fan may cause the system to slow down or cease entirely by overheating.
Make sure to power down your device and disconnect from any power sources before you begin.
Flip the laptop over so the model stickers face the ceiling.
Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
Use a Jimmy to pry apart the bottom of the case from the laptop.
Carefully detach the ribbon cable connecting the battery and the motherboard.
Use your hands to lift the battery out of the device.
Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
Unwind the Wi-Fi card wires from the side of the fan.
The wires need to be pulled down and around the first hook, as seen in image two.
Pull the black and white cables under the second hook and away from the fan.
Pull wires so they are out the way.
Loosen the six screws from the fan and heat sink.
Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
Pull the cable out of its socket on the motherboard.
Remove the fan from the laptop.
