Acer Chromebook CB5-571-C5XU Solid State Drive Replacement
  1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Solid State Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
  4. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the Solid State Drive upwards at an angle until it stops.
    • Be careful not to lift the Solid State Drive past where it stops, or you will risk breaking the hardware.
  5. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the Solid State Drive out from the socket in the direction of the angle at which it was resting.
    • The Solid State Drive should pull out with little effort. If it is resisting, do not pull harder, as this risks damage to the part.
David Flint
crwdns2935283:010/17/17crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 crwdns2935289:0UMass Dartmouth, Team S6-G1, Rockett Fall 2017crwdne2935289:0
UMASSD-ROCKETT-F17S6G1
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 460
