Acer Chromebook CB5-571-C5XU Battery Replacement
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery out and remove it from the laptop casing.
To reassemble your device, follow these guidelines in reverse order.
Kenneth Bowers
crwdns2935283:004/08/16crwdne2935283:0
1.432 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 886
