The battery supplies power to the laptop. The battery may need to be replaced if the laptop is a few years old, as batteries will start to lose their life after being used for a few years.
Remove the following eighteen screws using a Phillips #0 screwdriver.
Using the flat side of the spudger, pry open the bottom case of the laptop.
Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
Gently lift the battery out and remove it from the laptop casing.
To reassemble your device, follow these guidelines in reverse order.
