Acer Chromebook CB315-4H-P8FZ Display Panel Replacement
  1. Acer Chromebook CB315-4H-P8FZ Display Panel Replacement, Display Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB315-4H-P8FZ Display Panel Replacement, Display Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Close the lid.
    • Orient the laptop so that the part connecting screen and keyboard is facing you.
  2. Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the opening pick in-between crevice and separate parts by sliding the pry tool back and forth.
    • You may have to use light force.
    • Place the opening pick in between the border covering the screen and the screen and slide back and forth. Do this all around the entire border.
    • Pull off the loose border with your hands.
  3. Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use Philips #1 screwdriver to remove the two 5mm screws on each side of the opposite corners on the top of the Chromebook.
    • Use the Philips #1 screwdriver to remove the 5mm screws on each side of the bottom left and right corners of the screen.
    • Remove nuts and washers with blunt tweezers on the hinge connecting the screen to the keyboard.
    • Take screen off by pulling it away from the hinge connecting it to the keyboard.
  4. Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB315-4H-P8FZ Display Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off tape running over metal buckle that is holding down the display cable connector.
    • Unclip the small metal buckle by placing your finger or spudger under the buckle and lifting upwards.
    • Hold buckle and display cable connector then gently pull display cable connector out of socket
Charlize Jaques
crwdns2935283:002/20/25crwdne2935283:0
381 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-4, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-4, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G4
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 109
