Acer Chromebook CB3-532-C47C Motherboard Replacement
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB3-532-C47C Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
Sadie Brown
crwdns2935283:010/25/21crwdne2935283:0
1,012 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 crwdns2935289:0UMass Dartmouth, Team 3-2, Sinclaire Fall 2021crwdne2935289:0
UMASSD-SINCLAIRE-F21S3G2
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 946
