Acer Chromebook CB3-431-C5EX Battery Replacement
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
    There are two tabs on the battery opposite the connector side that need to be inserted into the retention slots or the battery won’t sit flat. Need to do this before reinserting the battery screws.
    Also, I found that #00 Phillips works best on the 4mm screws.
    John Burleson - crwdns2934203:0crwdne2934203:0
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB3-431-C5EX Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB3-431-C5EX Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the entire battery pack out of the laptop.
Elsa Bassett
crwdns2935283:004/18/17crwdne2935283:0
429 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G3, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S17-G3, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S17G3
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - crwdns2934203:0crwdne2934203:0
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,386
