Acer Chromebook CB0311-1H-C1MX Motherboard Replacement
  1. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a JIS #1 screwdriver, remove eleven 6.6 mm screws from the back cover.
  2. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Beginning at the hinges, use an iFixit Opening Tool to pry open the back case.
    • Continue using the iFixit Opening Tool around the entire edge of the case.
  3. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a JIS #1 screwdriver, remove all four 4.8 mm screws holding the battery in place.
  4. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently push on either side of the silver connector so that it no longer covers the battery cable.
    • Disconnect the battery cable by pulling it straight out.
    • This component is called the Flat Topped Connector.
  5. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  6. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement, Heatsink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement, Heatsink: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all four 4.7 mm screws from the heat sink with the JIS #1 screwdriver.
  7. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heatsink from the laptop.
  8. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step of the guide is intended only to help users locate the necessary components in the following steps. Please refer back to this step as needed.
    • This is the location of the palmrest cable detailed in Step 10 of this guide.
    • This is the location of the speaker cable detailed in Step 11.
    • This is the location of the Wi-Fi cables detailed in Step 12.
    • This is the location of the touchpad cable detailed in Step 13.
    • This is the location of the daughterboard cable detailed in Step 14.
    • This is the location of the LCD cable detailed in Step 15.
    • This is the location of the hinge detailed in Step 16.
  9. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the JIS #1 screwdriver, unscrew all five 4.7 mm screws.
    • Two of the screws also hold down the computer’s hinge.
    • Using the JIS #000 screwdriver, unscrew the one 2.4 mm screw.
  10. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the black tab that secures the palmrest cable in place.
    • Disconnect the palmrest cable by pulling it straight out.
    • The cable may be covered by tape.
  11. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the speaker cable by pulling it straight out.
  12. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black and white Wi-Fi cables by popping them off their pegs.
    • The cables may be covered by tape.
  13. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black tab that secures the touchpad cable in place.
    • Disconnect the touchpad cable by pulling it straight out.
  14. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the black tab that secures the daughterboard cable in place.
    • Disconnect the daughterboard cable by pulling it straight out.
  15. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the metal bar that secures the LCD cable in place.
    • Disconnect the LCD cable by pulling it straight out.
    • The cable may be covered by tape or stickers.
  16. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit opening pick, pry up the hinge holding the motherboard in place.
  17. Acer Chromebook CB0311-1H-C1MX Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift out the motherboard.
Izzy Hamann
crwdns2935283:001/24/25crwdne2935283:0
475 crwdns2915208:0crwdne2915208:0
Colorado Mesa University, Team 1-1, Kinney Spring 2025 crwdns2935289:0Colorado Mesa University, Team 1-1, Kinney Spring 2025crwdne2935289:0
CMU-KINNEY-S25S1G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 106
