Acer Chromebook C740-C4PE Touchpad Replacement
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touchpad from the device.
Jacob Kahn
crwdns2935283:010/17/17crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 crwdns2935289:0UMass Dartmouth, Team S6-G4, Rockett Fall 2017crwdne2935289:0
UMASSD-ROCKETT-F17S6G4
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 354
