This guide will show you how to change the Solid State Drive in Acer Chromebook C740-C4PE.
Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
Use the spudger or any other prying tool to pry the back plate off of the device.
Remove the 3.75 mm screw with a Phillips #0 screwdriver.
Pull the Solid State Drive out of the connector.
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
