This guide will demonstrate how to partially take apart the Acer Chromebook C740-C4PE, in addition to removing the heatsink.
Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
Use the spudger or any other prying tool to pry the back plate off of the device.
Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
Loosen the two Phillips-head screws on the fan attached to the heatsink.
Detach the two antennae cables from the WiFi card by gently pulling on them.
Gently pull the fan cable out of the motherboard.
Remove the cable routed through the fan.
Remove the heatsink from the motherboard.
What type of thermal paste is best used?
