Acer Chromebook C731-C8VE I/O Board Replacement
  1. Acer Chromebook C731-C8VE I/O Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE I/O Board Replacement, I/O Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement, I/O Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push up the latch connected to the ribbon cable on the I/O board with a nylon spudger.
    • Gently remove the cable from the I/O board with tweezers.
    • It is not required to remove the ribbon cable from the motherboard, only from the I/O board.
    • Remove the 5 mm screw from the I/O board using a JIS #00 screwdriver.
  8. Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C731-C8VE I/O Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently leverage the I/O board using the spudger until you can nudge it from underneath.
    • Carefully grab the I/O board with your fingers and remove it from the device.
Ethan Johnson
crwdns2935283:002/21/23crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-3, Kaufmann Spring 2023 crwdns2935289:0University of Kentucky, Team 1-3, Kaufmann Spring 2023crwdne2935289:0
UKY-KAUFMANN-S23S1G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 149
