This guide will mainly focus on removing the speakers. First, you will need to remove the back panel. Next, you will need to remove the battery.
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Pry the back panel open with the plastic opening tool.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Carefully pull out the battery wire connected to the battery port.
Slowly lift the battery to remove it from the Chromebook.
Unplug the speaker wire from the motherboard.
Carefully pull out the speakers from each side of the Chromebook.
