Acer Chromebook C720-2827 LED PCB Replacement
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2827 LED PCB Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
Sarah Westberg
crwdns2935283:003/11/19crwdne2935283:0
32,046 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 274
