This guide will provide you with the most practical way to remove the memory card off your C720-2420 Chromebook with a couple of steps.
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Use the plastic opening tool to carefully remove the bottom.
Remove the 3.6 mm Phillips screw that secures the SSD in place.
