Acer Chromebook C720-2420 Keyboard Replacement
  1. Acer Chromebook C720-2420 Keyboard Replacement, Back Cover Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement, Back Cover Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Keyboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
    BEFORE disconnecting, first get the battery loose in the laptop case. At the front of the battery (bottom of this picture) there are two tiny rectangular tabs that stick off the battery and engage in two matching sockets molded into the laptop case. Push the battery toward the hinge (upward in picture) so that the tabs come out of the sockets and you can swing the battery up to free it. NOW disconnect the 8-pin battery connector. Much easier.
    Mason Gilbert - crwdns2934203:0crwdne2934203:0
  5. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  6. Acer Chromebook C720-2420 Keyboard Replacement, cooling fan / CPU heat sink assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement, cooling fan / CPU heat sink assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
    These two wire connectors are exactly like snaps on clothing, except super tiny. They want to pop straight UP, i.e. perpendicular to the board.
  8. Acer Chromebook C720-2420 Keyboard Replacement, Memory: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement, Memory: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  9. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the SSD.
  10. Acer Chromebook C720-2420 Keyboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the speaker cable from the motherboard.
  11. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the display cable from the motherboard.
  12. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the wire for the 2 PIC connectors.
  13. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
  14. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Carefully remove the ribbon cable.
  15. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the ribbon cable
  16. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable.
  17. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the motherboard.
  18. Acer Chromebook C720-2420 Keyboard Replacement, Keyboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement, Keyboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speakers located on both left and right bottom corners of the Chromebook with a plastic opening tool.
  19. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.6 mm Phillips screws holding the USB and SD card port with a PH0 screwdriver.
    • Lift out and remove the port.
  20. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.6 mm Phillips screws holding the LED sensors.
    • Remove the LED Sensors.
  21. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the black tab on the ZIF connector to release the ribbon cable.
    • This ribbon is fragile, do not use excessive force.
  22. Acer Chromebook C720-2420 Keyboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave only the single ribbon cable.
Jessica Beckford
crwdns2935283:002/12/18crwdne2935283:0
527 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S15-G4, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S15-G4, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S15G4
Huh? This doesn’t tell how to replace the keyboard.
Dave Burton - crwdns2934203:0crwdne2934203:0
After the last step unscrew the 3 screws at the top of the device holding the display assembly to the top portion, then bend those up and you can pull the whole cover with the keyboard and touchpad off and slide the new one in.
Jacob Pearlson -
crwdns2942667:0crwdne2942667:0 5,183
