This guide will provide you with simple and clear steps on how to replace a dead battery in an Acer Chromebook C720-2420.
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Use the plastic opening tool to carefully remove the bottom.
Remove the two 3.6 mm Phillips screws holding the battery in place.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
