Acer Chromebook C720-2103 Battery Replacement
  1. Acer Chromebook C720-2103 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2103 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2103 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C720-2103 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
Matthew Holt
crwdns2935283:010/17/17crwdne2935283:0
633 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 crwdns2935289:0UMass Dartmouth, Team S66-G3, Rockett Fall 2017crwdne2935289:0
UMASSD-ROCKETT-F17S66G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 879
