Acer Chromebook C710-2847 Wireless Card Replacement
  1. Acer Chromebook C710-2847 Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Wireless Card Replacement, Acer Chromebook C710-2847 Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
    Bradley,
    If I replace the chrome os Hard drive with one that has a Linux distro already installed will the linux work normally or is there something built in to stop it.
    It's something I do with an old dell I use for checking out distros.
    Regards,
    Jack
    jack martin - crwdns2934203:0crwdne2934203:0
    I guess it's too late to answer this question now, but C710 is not IBM PC-compatible so standard linux distros do not run normally on it without any modifications.
    You can flash a IBM PC-compatible bootloader(coreboot+SEABIOS) on it to run other linux distros.
    cdac1234 -
    Any suggested source for getting the 4 Gb RAM upgrade? Does this RAM have a model number?
    rwells78 -
    What is the hard drive called, or it's specific name, so that I may search around for a replacement, before taking my laptop apart?
    Jennifer Munoz - crwdns2934203:0crwdne2934203:0
    Mine is a Seagate ST320L T020
    Marshall Gates -
    do not so what the second picture shows and leave the battery in!
    brayton1234567 - crwdns2934203:0crwdne2934203:0
  4. Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  6. Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  7. Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 Wireless Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
Bradley Pavy
crwdns2935283:009/30/13crwdne2935283:0
1,257 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-3, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-3, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G3
If you replace the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,146
