Acer Chromebook C710-2833 SD Card Reader Replacement
  1. Acer Chromebook C710-2833 SD Card Reader Replacement, SD Card Reader: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $3.99
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 SD Card Reader Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to de-solder the nodes shown on the SD Card Reader. There will be 11 nodes above (see the wide red rectangle), and one node on each side (see two red squares).
    • Remove and replace the SD Card Reader.
Chase Wilderman
crwdns2935283:010/31/18crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G6, Harley Fall 2018 crwdns2935289:0IUPUI, Team S1-G6, Harley Fall 2018crwdne2935289:0
IUPUI-HARLEY-F18S1G6
crwdns2942667:0crwdne2942667:0 1,090
