Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
crwdns2935229:05crwdne2935229:0
Sakiynah Howard
crwdns2935283:010/17/17crwdne2935283:0
1,024 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 crwdns2935289:0UMass Dartmouth, Team S1-G3, Simcock Fall 2017crwdne2935289:0
UMASSD-SIMCOCK-F17S1G3
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,780
